?lin?idiku reset?!
g0lfar
?lin?idiku reset?!
kas keegi oskab ?elda kuidas reset'ida ?li n?idikut (golf IV).
?li ja ?lifiltrer vahetati ?ra aga unustati vist see n?idik nullida.
n??d igakord, kui autol s??te sisse keeran, armatuuril vilgub "service oil"
oskab keegi n?u anda?
- Tänanud: 102 korda
- Tänatud: 196 korda
See oleneb ju spidon?idust mis kellelgi on-kas nullid ?ra ainult ?livahetus-hoolduse OEL v?i ka need teised IN 01 v?i IN 02. Kui liiga palju nullid siis lihtsalt ei n?idata ?ieti j?rgmist suuremat hooldust.
?liservice
Viimati muutis kaimoy, 20 Aug 2014, 21:30, muudetud 1 kord kokku.
- Pikksilm
- Auto: G2, T2b
- Tänatud: 6 korda
Ei t??taAlgselt postitas: PS
G3- l k?ib see n?idikute juures olevate kahe nupuga, ehk on G4-l sama.
S??de sisse
p?evase l?bis?idu nupp alla
s??de v?lja
nupp lahti
teist nuppu hoida all, kuni tulevad ette viis kriipsu
nupp lahti
p?evase l?bis?idu nupp alla ja lahti
Kui vaja ka IN01 ja IN02 nullida, siis korrata seda nendega sama moodi ( kriipsude tulekuni)
s??de sisse
s??de v?lja
Proovisin korduvalt, tirisin l?paka k?rvale ja tegin step-by-step ja ikkagi. Tulid ette viis kriipsu, vajutasin vasaku nupu alla ja lahti aga IN02 j??b ikka hiljem uuesti s??det sisse keerates ette. Eks p??rdun targemate poole.
SETTING VW /// SERVICE INTERVALS
Here are the instructions for reseting and programming the service reminder
for the Golf ///, Jetta /// and other such car for the oil servie OEL, and the
service intervals IN1 and IN2.
This information has been obtained from a german repair manual for the cars and
has been tried successfully on the authors 1994 Golf GL, US Model.
Displays:
IN00 - no service is required; this is the standard display
OEL - when 7500miles have been reached before the yearly service interval
IN01 - indicates it is time for the yearly service including oil change
IN02 - indicates it is time for the 15,000mile service with extra checks
The computer has counters that count not only the miles from the odometer to
flag for services but also counts time to flag for servies.
TO RESET THE INDIVIDUAL INDICATOR COUNTERS:
1. Turn on ignition (do not start the car)
2. Press the trip-reset button on the odometer (the trip value will not be
reset to zero but will reappear when the procedure is completed)
3. Turn off the ignition and then release the trip-reset button.
In the LCD display, you will see the display "OEL".
Using the button to set the MINUTES (lower one) of the digital clock, you will
reset the OEL interval counter. Press it, hold, release. Five (5) horizontal
lines will appear in the LCD display.
4. Press and release the trip-reset button
In the LCD display, you will see the display "IN01". Repeate the process under
step 3 above to reset this counter when required.
5. Again press the trip-reset and reset the IN02 counter if necessary.
If doing an oil change, ONLY reset the OEL counter.
If doing the IN01 service, reset BOTH the OEL and IN01 counters.
If doing the IN02 service, reset ALL of them, the OEL, IN01 and IN02 counters.
6. Turn on ignition (do not start the car).
7. After the appearance of the "IN00" display, turn off the ignition.
8. You are done. The trip counter should read as it did before you started.
Displays:
2007 Passat [i]sold[/i]
2008 Jetta [i]sold[/i]
2004 Passat [i]sold[/i]
1993 Golf [i]sold[/i]
1986 Golf [i]sold[/i]
- Pikksilm
- Auto: G2, T2b
- Tänatud: 6 korda
L?hen proovin hiljem, eks annan teada.
Doppel-wobber'ist vaatas saksakeeles vastu selline tekst, kahjuks saksakeelt ei valda
Z?ndung einschalten
Auswahlknopf (km-Angabe) gedr?ckt halten und Z?ndung dabei ausschalten
Knopf loslassen -> nun erscheint OEL in der Anzeige
Minutenknopf der Uhr solange dr?cken bis Anzeige gel?scht wird (Service damit r?ckgesetzt)
mit dem Auswahlknopf zu den Service IN01 und IN02 wechseln; hier selbe Prozedur
Z?ndung einschalten - alles okay
Z?ndung einschalten
- Pikksilm
- Auto: G2, T2b
- Tänatud: 6 korda
Sain asja korda. Point oli selles, et iga asi OIL, IN01 ja IN02 tuleb eraldi resetida ja vahpeal s??ded n?ppida ei ole vaja. Ehk siis
GOLF 3
Faas 1- saada men??sse sisse:
1. S??de sisse. (Autot ei ole vaja loomulikult k?ima panna !)
2. Vasak nupp alla, hoia all.
3. S??de v?lja
4. Lase vasak nupp lahti.
N??d l?i vist kirja OIL ette, ehk siis oled resetimise men??s.
Faas 2- Resetimine:
1. Kui kiri OIL on ees siis hoia paremat nuppu 5 sekundit all, kuniks ekraanile ilmub "- - - - -" mis suht varsti kustub ja lase parem nupp lahti
2. Vajuta vasakut nuppu ja vali mida reset'ida tahad "OIL" , "IN 01" ja "IN 02" vahel, see mida resetida tahad selle peale j?ta ja lase nupp lahti.
2.a - Kui soovid ka midagi muud kolmest v?i lausa k?iki resettida, siis ?ra s??det vahepeal sisse keera vaid hoia uuesti paremat nuppu all kuni tulevad kriipsud, lased parema nupu lahti ja vasakust vahetad j?lle selle peale mida seekord resetida tahad.
3. Kui oled oma valitud asjad saanud ?ra resetida siis lase k?ik nupud lahti. Korraks s??de sisse ja s??de v?lja. Minul ilmus n??d ette kiri "IN 00".
H?va kasutamist.
[Muudetud: 18-12-2007 pikksilm]
GOLF 3
3. S??de v?lja
Faas 2- Resetimine:
H?va kasutamist.
- Pikksilm
- Auto: G2, T2b
- Tänatud: 6 korda
Ehk siis:
Algselt postitas: txx
Seda saab nullida nagu ?livahetuse oma ja seda on eelnevalt juba mitu korda r??gitud.
Auto manuaalis on see ka olemas aga kahjuks peast ei m?leta aga otsingust kindlasti leiab vajaliku ?lesse
S??de sisse, hoia all paremat p?evast l?bis?idu nuppu, s??de v?lja, s??de sisse, nupp lahti, vasakut nuppu paremale, s??de v?lja.
N??d kui s??de sisse panna ei tohiks enam service insp kirja olla
