K?igepealt siis tasuks veenduad, kus kohast tross puru on.
Kui tross on salongist puru siis on asi lihtne... hoova juurest
n?pitsatega t?mmata, aga kui tross on kapoti alt puru siis
on asi veel lihtsam
Vaja l?heb ainult akutrelli koos 8 puuriga ja mingit L kujulist v?tit
(mina kasutasin t?hikupeaga v?tit)
alustuseks tasuks puurida auk siia
Seej?rel v?tta v?ti ubes selline nagu mul..
Lykata ots sealt august pool viltu sisse..
Keerad nauke alla et ots l?heks vastu seda hooba, kus tross kinni oli(selle suure vedru all)..
Ja t?mba v?tit natuke vasakule..
ja kapott hyppab lahti..
Lisan veel igaksjuhuks ka yhe video kuidas asi praktiliselt k?is
VIDEO
Loodan, et kellelgi tross ei purune, nagu mul.
Kuid kui nii juhtub siis loodan, et sellest ?petusest oli abi!Your browser does not support drag'n'drop file uploads.Please use the fallback form below to upload your files like in the olden days.Your browser does not support drag'n'drop file uploads.Please use the fallback form below to upload your files like in the olden days.Your browser does not support drag'n'drop file uploads.Please use the fallback form below to upload your files like in the olden days.
