limp mode.i läks
raix130290
limp mode.i läks
Address 01: Engine Labels: 03G-906-021-BMM.clb
Control Module Part Number: 03G 906 021 MS HW: 028 101 271 9
Component and/or Version: R4 2,0L EDC G000AG 9390
Software Coding: 0000078
Work Shop Code: WSC 81000 205 52844
VCID: 7CF7127B3C1EBCFEC8B-5072
3 Faults Found:
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 5
Reset counter: 255
Mileage: 293293 km
Time Indication: 0
Date: 2014.12.25
Time: 17:02:24
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001000
Temperature: 57.6°C
(no units): 0.0
005715 - Please check DTC Memory of ABS Controller
P1653 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 294883 km
Time Indication: 0
Date: 2015.01.12
Time: 16:13:17
Freeze Frame:
RPM: 882 /min
Speed: 6.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001011
Torque: 139.1 Nm
Bin. Bits: 0 01 0
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 296054 km
Time Indication: 0
Date: 2015.02.01
Time: 15:27:12
Freeze Frame:
RPM: 252 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001000
Idle Stabilization: 0.0°KW
RPM: 126 /min
tulin sõidust ja peale 2 tunnist seismist läks käima alles pikalt käiates.
esp tuli põles, eelsüüte tuli vilkus ja mootori tuli põles ka.
dsg vahetas väga kahtlaselt käike ja 30 km sõitsin 5 käiguga, kuuendale ei vahetanud.
kodus kustutasin veakoodid ja kõik korras.
milles võib viga seisneda?
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 255
Mileage: 293293 km
Time Indication: 0
Date: 2014.12.25
Time: 17:02:24
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001000
Temperature: 57.6°C
(no units): 0.0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 294883 km
Time Indication: 0
Date: 2015.01.12
Time: 16:13:17
Freeze Frame:
RPM: 882 /min
Speed: 6.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001011
Torque: 139.1 Nm
Bin. Bits: 0 01 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 255
Mileage: 296054 km
Time Indication: 0
Date: 2015.02.01
Time: 15:27:12
Freeze Frame:
RPM: 252 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 10.56 V
Bin. Bits: 00001000
RPM: 126 /min
Priidik333
- Telefon: 53644681
Re: limp mode.i läks
Ilmselt selles Engine speed sensoris või selle ühendustes
anonymous2
- Tänanud: 88 korda
- Tänatud: 47 korda
ära enne mingit uut andurit ostma hakka,
vaata mootorifiltri all käigukasti pealt peaks kusagilt jooksma mingi kaablikõri üle, tee lahti ja vaata üle, mis seisus juhtmed seal on. (pidavat tüüpviga olemas, et kõri närib juhtmed läbi)
Endal oli sama lugu eelmine aasta. Lõi Limpi ja siis seisis paar h ja kõik korras nagu poleks midagi olnud ja täiesti suvaliselt hetkel jälle limp mode.
Samuti näitas veakoodiks mootoripöörete andurit.
raix130290
juhtmetes võib viga olla küll, sest mingi aeg ei töödanud kunde poolne peegli suunatuli.
Seda juhtmekimpu liigutades sain lõpuks tööle tule, ja siiamaani töötab.
Aga seda eelnimetatud jama on 1-el korral veel juhtund. 2x poole aasta jooksul siis.
peaks siia autoelektriku poole pöörduma? või oskab keegi öelda et mis moodi seda vända anduri korras olekut kontrollida?
- Tänanud: 95 korda
- Tänatud: 189 korda
raix130290 kirjutas:peaks siia autoelektriku poole pöörduma? või oskab keegi öelda et mis moodi seda vända anduri korras olekut kontrollida?
kui ligipääs ossile siis saab ka selle seadmega impulssi kontrollida.anonymous2 kirjutas:vaata mootorifiltri all käigukasti pealt peaks kusagilt jooksma mingi kaablikõri üle, tee lahti ja vaata üle, mis seisus juhtmed seal on. (pidavat tüüpviga olemas, et kõri närib juhtmed läbi)
Viimati muutis GTI, 04 Veebr 2015, 13:46, muudetud 1 kord kokku.
Põhjus: .
Põhjus: .
anonymous2
- Tänanud: 88 korda
- Tänatud: 47 korda
no kui käed küljes, siis pole endal ka ju raske yle vaadata. Mulle jõudis info ka selle kaablikõri kohta saksa autos töötaa inimese kaudu, muidu oli ka plaan kohe andurit vahetama hakata. Endal käis see samuti, et esimesel korral veeresin koju tagasi limp mode all ja kui puksiir kohale jõudis 1-2h pärast oli kõik korras. teisel korral jälle sama seis. (möödas oli esimesest korrast kenake 3-4kuud)raix130290 kirjutas:juhtmetes võib viga olla küll, sest mingi aeg ei töödanud kunde poolne peegli suunatuli.
raix130290
täna siis järgmine anomaalia.
seisan autoga kohapeal, ühtegi asja ei näpi ja järsku hakkab kollale parking brake tuli põlema ja punane hüüu märk vilkuma, autoga sõitsin koju, terve tee pinises.
Sellest sain aru et vasak poolne käsipiduri mootor ei tööta, parem funktsioneeris kenasti.
koju jõudes mängisin selle käsipiduriga peale-maha ja järsku on kõik ok. hetkel toimib, aga kui kaua ei tea.
kust peaks viga otsima.? see ka veel et kui käsipidur peale panna siis parem poolne mootor töötab kiiremini, st paneb piduri kiiremini peale.
veakoodid mis sain.
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Control Module Part Number: 3C0 907 801 B HW: 3C0 907 801 B
Component and/or Version: EPB VC8HC001 013 0001
Software Coding: 0000012
Work Shop Code: WSC 05311 000 00000
VCID: 2149030FF83C3116BBD-8074
4 Faults Found:
02443 - Control Head
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 10:03:25
Freeze Frame:
Voltage: 14.18 V
Count: 49
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:42
Freeze Frame:
Voltage: 12.01 V
Count: 46
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 6
Reset counter: 0
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:19
Freeze Frame:
Voltage: 12.53 V
Count: 86
02430 - Left Parking Brake Motor (V282) Resistance to Movement
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:19
Freeze Frame:
Voltage: 12.42 V
Count: 88
veakoodid mis sain.
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 10:03:25
Freeze Frame:
Voltage: 14.18 V
Count: 49
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:42
Freeze Frame:
Voltage: 12.01 V
Count: 46
Freeze Frame:
Fault Priority: 1
Fault Frequency: 6
Reset counter: 0
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:19
Freeze Frame:
Voltage: 12.53 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 254
Mileage: 296544 km
Time Indication: 0
Date: 2015.02.05
Time: 09:03:19
Freeze Frame:
Voltage: 12.42 V
Count: 88
Viimati muutis raix130290, 05 Veebr 2015, 15:06, muudetud 1 kord kokku.
raix130290
anonymous2
- Tänanud: 88 korda
- Tänatud: 47 korda
kusagilt kõrvu jäänud, et pakutakse ka niiöelda vahetusfondi või midagi sellist. hind oli siis 180 kandisraix130290 kirjutas:suht kallis ka see mootor, uue hinnapakkumine oli 275.-
Aga kahtlen, et see nüüd mootorit limp-i ajab.
Viimati muutis anonymous2, 05 Veebr 2015, 20:58, muudetud 1 kord kokku.
raix130290
- Siim
- Tänanud: 21 korda
- Tänatud: 4 korda
Kässari kohta:
Kunagi b6'el sai ilusti ära pestud ja puhstatud roostest, oli kinni jäänd juba mootor, uus määre sisse hammasrataste vahele ja mõra sai epoga üle valatud, 4 aastat toiminud juba.
