Täna sa tõdetud fakti, et autod lähevad üle öö ja seistes katki. Täna autot käivitades tundus kahtlane, et võtme süütelukku pannes ükski tuli armatuuris põelma ei hakka, auto läheb küll käima ja ka näidikuteplokk sel hetel hakkab sekundiks tööle aga siis kustub.
https://youtu.be/HP8uhIOfiiI
Passat b6 näidukuplokk
- volkar
- Auto: Passat B6
- Tänanud: 30 korda
- Tänatud: 34 korda
Väga sarnane kirjeldus rooliluku rikkele
Kood: Vali kõik
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Control Module Part Number: 3C0 920 870 G HW: 3C0 920 870 G
Component and/or Version: KOMBIINSTRUMENT VD1 4038
Software Coding: 0005105
Work Shop Code: WSC 00011 888 96745
VCID: 275C76389639F07EEB-8072
2 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 10
Reset counter: 200
Mileage: 249343 km
Time Indication: 0
Date: 2018.04.07
Time: 00:00:01
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 200
Mileage: 249343 km
Time Indication: 0
Date: 2018.04.07
Time: 00:00:43
Address 17: DTCs clearedSaturday,07,April,2018,18:50:48:54500
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
Address 01: Engine Labels: 03G-906-021-BMM.clb
Control Module Part Number: 03G 906 021 MR HW: 028 101 211 9
Component and/or Version: R4 2,0L EDC G000SG 9389
Software Coding: 0000072
Work Shop Code: WSC 00011 888 81093
VCID: 7BF47A483A31849EDF-802E
1 Fault Found:
053272 - Control Module for Instrument Cluster
U1018 - 000 - Missing Signal for Ambient Temperature - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 249343 km
Time Indication: 0
Date: 2018.04.07
Time: 00:29:21
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Temperature: 6.3°C
Temperature: 2.7°C
Temperature: 5.4°C-
Andrusito
- Auto: VW Passat B6 2.0 FSI BVY 6-manual
Oli midagit sellest operast tuttaval, peale auto seismist. Sõitsis töökotta, seal võeti plokki korraks välja ja kohe tagasi ja kõik hakkas tööle. Ilmselt kontakti viga.
