MB kompressor Corradole peale
samzik
Telefon: 55558855
lets say we want 240hp out of our 12v's which put out say, 160hp; It ~should take 9-10psi (non-intercooled) to get us there.
engine airflow= 260cfm
airflow we need= "9.5psi"x260cfm=429cfm
sc discplacement:
m45= 0.75l or 45.8
m62= 1.00l or 61
m90= 1.50l or 91.5
m112= 1.84l or 112.3
here's how fast each model needs to be spun to achieve our goal:
m45-
forget it.
m62-
(61*13500rpm*.92)/1728=438cfm
m90-
(91.5*9000rpm*.92)/1728=438cfm
m112-
(112.3*7300rpm*.92)/1728=436cfm
Unsure what the redline of the m62 is but 13,500 may be close to it . Either way, the m62 wouldn't provide as much room for ~expansion.
allikas : http://forums.vwvortex.com/zerothread?id=2948434" onclick="window.open(this.href);return false;
Sobiv rihma pikkus valzi autole sai siis 1675 minu m?lu j?rgi.
[Edited on 25-7-2007 by samzik]
M-Tech
Tänatud: 30 korda
Tee siis ilusti joonis ka asjast, et hiljem saaks seda n?iteks sinu kaudu tellida, kui kellegil vaja l?heb.
S??staks k?vasti installi aega.
samzik
Telefon: 55558855
Eks ma ilmselt ?ritan teha ja selle n? jala mille peale ehitasin selle nr peaks kah ?les kirjutama mis mootori k?lge k?ib.
