Five Black Friday offers
Instead of a one weekend offer, we will post five Black Friday offers that are valid for the whole weekend. Now it is an excellent opportunity to grab parts of the suspension, cooling, brakes and exhaust at much lower price - many of these products are in our stock. Here they are!
Mishimoto products -10%
You can find everything for engine cooling from Mishimoto! For example there is a wide range of radiators, coolers (also in model specific kits), fans, silicone hoses and even a wheel nuts, all with BF discount. Mishimoto radiators are much bigger than OEM so they are also a great compromise for any car - no more cooling problems!
Race.fi: Mishimoto products
Magnaflow catalysts -10 %
Cleaning power without power loss! Magnaflow performance catalytic converters cleans exhaust gasses without any flowing loss like in original catalysts. Ceramic catalyst is cheap and a good choice when replacing the old broken OEM catalyst for a lightly tuned car. Metallic catalyst is a good choice when you need more flow and a little more impact resistance.
Race.fi: Magnaflow catalysts
All Eibach products -15 %
Little or little more lowering but no adjustment, with or without shocks? Eibach B12 Pro-kit / Sportline kits has a lowering usually between 30-60mm and thats it! Suspension kit is a great update for example to replace the old shocks/springs which also gives a nice little lowering which improves handling and comfort. For adjustable needs, we recommend the Eibach Pro-street S coilover kit which has a height adjustment. Eibach also has a wide range of other suspension parts like sway bars, spacers and bolts/nuts, check these our from link below.
[url=ttps://www.race.fi/en/brand/35/eibach/1]Race.fi: Eibach products[/url]
Black Diamond -10%
Black Diamond has a wide range of braking parts for the streets and also for race use - there is lots of options
Brake discs are available in grooved, drilled or both - its your choice! Black Diamond has a low dust level, high friction and excellent heat resistance, if needed, pads are also suitable for race use.
Race.fi: Black Diamond products
Turbosmart products -10 %
Turbosmart has all the turbo products you need, there is a wide range of dump valves, wastegates, bleeds and spare parts - all are in discount, even the little pieces! Most popular Turbosmart products at the moment are Turbosmart Boost-Tee bleeds which are great for boost pressure adjustment, we also keep these always in stock. Check the range and grab yours from the link below.
Race.fi: Turbosmart products
Have a great weekend!
-Riku
