VW Passat B6 veakoodid.
martzz
Telefon: 56681991
Lugemata postitus Postitas martzz »
Tegemist on siis Passat B6 2006 a, 125kw. Ja ilmnesid sellised veakoodid, ehk oskab keegi aidata. :(
Address 01: Engine Labels: 03G-906-018-BMN.clb
Control Module Part Number: 03G 906 018 EM HW: 03G 906 018 EM
Component and/or Version: R4 2.0l PPD1.2 G 4369
Software Coding: 0000078
Work Shop Code: WSC 70521 146 69816
VCID: 74EC6BBA176C39BE9BD
4 Faults Found
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 006 -
Freeze Frame
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 99
Reset counter: 40
Mileage: 287485 km
Time Indication: 0
Date: 2013.09.20
Time: 11:14:20
Freeze Frame
RPM: 800 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Bin. Bits: 00000000
Text: Kein Messwert verfuegbar
Absolute Pres.: 0.0 mbar
005782 - Powertrain Data Bus
P1696 - 008 - Implausible Message from Steering Column Controller
Freeze Frame
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 287485 km
Time Indication: 0
Date: 2013.09.20
Time: 11:14:21
Freeze Frame
RPM: 800 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 14.24 V
Bin. Bits: 11001100
Bin. Bits: 01000000
000665 - Boost Pressure Regulation
P0299 - 006 - Control Range Not Reached - Intermittent
Freeze Frame
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 9
Mileage: 287636 km
Time Indication: 0
Date: 2013.09.22
Time: 11:30:26
Freeze Frame
RPM: 2272 /min
Torque: 296.0 Nm
Speed: 117.0 km/h
70.98 %
Voltage: 14.46 V
Pressure: 2300.4 mbar
Pressure: 1874.4 mbar
005714 - Please check DTC Memory of Transmission Controller
P1652 - 008 -
Freeze Frame
Fault Priority: 0
Fault Frequency: 13
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.43 V
Bin. Bits: 00000001
Bin. Bits: 00000000
