ei hakka uut teemattegema. sõbral 85kw tdi'ga probleem läheb lambist limpi, täiesti suvalistel aegadel vahel kiirendades, vahel rahulikult sõites. vea koofi annab:
Sunday,04,January,2015,21:56:50:62939,VCDS Version: Release 12.12.0,Data version: 20130910
038 906 019 BR,,1.9l R4 EDC G000SG 1064,
,Group A:,'010,,,,Group B:,'011,,,,Group C:, Not Running
,,MAF,Atmos. pressure,Intake air press.,Throttle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP,,,,,
,TIME,850-1050,sensor -f96-,2000-2200,100%,TIME,2850-3150,2000-2150,2000-2200,40-95%,TIME,,,,
Marker,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %,STAMP,,,,
,0.00,553.7,989.4,989.4,0.0,0.43,840,1162.8,989.4,19.9,,,,,
,0.84,539.0,989.4,989.4,0.0,1.25,861,1162.8,989.4,19.9,,,,,
,1.66,543.9,989.4,989.4,0.0,2.09,966,1305.6,989.4,19.9,,,,,
,2.54,592.9,989.4,969.0,20.0,2.98,1449,1377.0,969.0,19.9,,,,,
,3.42,563.5,989.4,979.2,30.6,3.86,1470,1407.6,989.4,20.3,,,,,
,4.30,543.9,989.4,999.6,37.3,4.74,1596,1519.8,1009.8,19.9,,,,,
,5.16,578.2,989.4,1009.8,41.2,5.56,1701,1601.4,1020.0,19.9,,,,,
,5.98,646.8,989.4,1040.4,44.7,6.42,1995,1713.6,1050.6,19.9,,,,,
,6.84,558.6,989.4,1071.0,43.9,7.28,2457,1672.8,1101.6,21.5,,,,,
,7.72,597.8,989.4,1111.8,44.7,8.16,3108,1662.6,1152.6,27.5,,,,,
,8.60,641.9,989.4,1224.0,45.1,9.04,3801,1570.8,1275.0,37.9,,,,,
,9.47,602.7,989.4,1336.2,40.0,9.90,3528,1030.2,1254.6,41.4,,,,,
,10.29,445.9,989.4,1091.4,21.6,10.71,2226,1723.8,1081.2,19.9,,,,,
,11.13,558.6,989.4,1091.4,59.6,11.56,2352,2182.8,1101.6,19.9,,,,,
,12.00,558.6,989.4,1111.8,70.6,12.44,2520,2182.8,1111.8,19.9,,,,,
,12.88,563.5,989.4,1132.2,73.3,13.32,2709,2162.4,1152.6,20.7,,,,,
,13.75,539.0,989.4,1162.8,74.9,14.16,2898,2131.8,1183.2,20.3,,,,,
,14.55,583.1,989.4,1224.0,74.9,14.96,3087,2111.4,1254.6,21.9,,,,,
,15.39,592.9,989.4,1285.2,74.9,15.82,3318,2101.2,1346.4,21.9,,,,,
,16.26,700.7,989.4,1438.2,74.9,16.70,3696,2091.0,1611.6,35.9,,,,,
,17.14,1004.5,989.4,1815.6,74.5,17.58,4074,2091.0,1917.6,40.2,,,,,
,18.02,931.0,989.4,1958.4,74.5,18.44,4368,1999.2,1958.4,41.4,,,,,
,18.85,1009.4,989.4,1938.0,56.5,19.26,3927,1050.6,1540.2,45.8,,,,,
,19.69,480.2,989.4,1152.6,43.9,20.13,2814,2121.6,1173.0,21.9,,,,,
,20.58,882.0,989.4,1275.0,76.1,21.02,2898,2142.0,1377.0,22.3,,,,,
,21.46,1029.0,989.4,1458.6,79.6,21.90,3024,2121.6,1540.2,23.5,,,,,
,22.34,1048.6,989.4,1632.0,79.6,22.75,3171,2111.4,1703.4,23.1,,,,,
,23.15,960.4,989.4,1754.4,79.2,23.55,3339,2101.2,1795.2,24.3,,,,,
,23.96,891.8,989.4,1846.2,79.2,24.39,3486,2091.0,1887.0,23.9,,,,,
,24.82,911.4,989.4,1927.8,79.2,25.26,3633,2091.0,1948.2,23.1,,,,,
,25.70,940.8,989.4,1968.6,78.8,26.14,3780,2091.0,1968.6,27.1,,,,,
,26.58,960.4,989.4,1978.8,78.8,27.02,3906,2091.0,1989.0,31.9,,,,,
,27.43,1029.0,989.4,1999.2,78.8,27.83,4032,2091.0,2019.6,35.5,,,,,
,28.27,1068.2,989.4,2019.6,78.8,28.69,4137,2080.8,2019.6,37.1,,,,,
,29.14,945.7,989.4,2009.4,71.8,29.57,4158,1060.8,1917.6,90.0,,,,,
,30.02,499.8,989.4,1326.0,0.0,30.46,3066,1734.0,1111.8,19.9,,,,,
,30.90,553.7,989.4,1142.4,66.3,31.34,2961,2131.8,1213.8,26.3,,,,,
,31.76,622.3,989.4,1315.8,81.6,32.17,2961,2131.8,1346.4,20.7,,,,,
,32.57,788.9,989.4,1397.4,81.6,32.98,3003,2131.8,1468.8,26.7,,,,,
,33.41,916.3,989.4,1560.6,91.4,33.84,3045,2131.8,1632.0,25.5,,,,,
,34.27,1087.8,989.4,1693.2,89.8,34.71,3087,2101.2,1734.0,25.5,,,,,
,35.16,1063.3,989.4,1683.0,62.7,35.59,3129,2040.0,1642.2,19.9,,,,,
,36.01,1087.8,989.4,1621.8,60.4,36.43,3171,2019.6,1611.6,19.9,,,,,
,36.85,1092.7,989.4,1611.6,60.4,37.29,3192,2009.4,1621.8,20.3,,,,,
,37.73,965.3,989.4,1621.8,60.0,38.17,3234,2091.0,1632.0,19.9,,,,,
,38.61,1033.9,989.4,1672.8,62.7,39.05,3297,2019.6,1672.8,20.3,,,,,
,39.49,994.7,989.4,1672.8,58.4,39.93,3318,1958.4,1642.2,19.9,,,,,
,40.37,999.6,989.4,1632.0,58.4,40.78,3360,1948.2,1632.0,20.3,,,,,
,41.21,955.5,989.4,1642.2,58.4,41.61,3381,1948.2,1642.2,19.9,,,,,
,42.04,1033.9,989.4,1642.2,58.0,42.49,3402,1927.8,1632.0,19.9,,,,,
,42.93,1053.5,989.4,1642.2,58.8,43.37,3444,1948.2,1652.4,19.9,,,,,
,43.81,882.0,989.4,1662.6,58.8,44.25,3381,1122.0,1611.6,53.0,,,,,
,44.69,494.9,989.4,1213.8,0.0,45.10,3360,1020.0,1091.4,39.8,,,,,
,45.50,480.2,989.4,1050.6,0.0,45.91,3297,1020.0,1040.4,39.8,,,,,
,46.32,494.9,989.4,1030.2,0.0,46.78,3234,1020.0,1020.0,39.8,,,,,
,47.21,406.7,989.4,1020.0,0.0,47.65,3150,1020.0,1030.2,39.8,,,,,
,48.09,637.0,989.4,1020.0,0.0,48.53,3087,1009.8,1020.0,39.8,,,,,
,48.97,627.2,989.4,1020.0,0.0,49.40,3024,1009.8,1020.0,39.8,,,,,
,49.80,656.6,989.4,1020.0,0.0,50.21,2961,1009.8,1020.0,39.8,,,,,
,50.64,764.4,989.4,1020.0,0.0,51.09,2898,999.6,1020.0,39.8,,,,,
,51.53,676.2,989.4,1020.0,0.0,51.97,2835,999.6,1020.0,39.8,,,,,
,52.41,641.9,989.4,1020.0,0.0,52.85,2772,999.6,1020.0,39.8,,,,,
,53.29,583.1,989.4,1020.0,0.0,53.72,2709,989.4,1020.0,39.8,,,,,
,54.12,661.5,989.4,1020.0,0.0,54.52,2667,989.4,1009.8,39.8,,,,,
,54.94,705.6,989.4,1009.8,0.0,55.37,2604,989.4,1009.8,39.8,,,,,
,55.81,607.6,989.4,1009.8,0.0,56.25,2541,979.2,1009.8,39.8,,,,,
,56.69,700.7,989.4,1009.8,0.0,57.13,2478,979.2,1009.8,39.8,,,,,
,57.57,739.9,989.4,1009.8,0.0,58.00,2415,979.2,1009.8,39.8,,,,,
,58.43,700.7,989.4,1009.8,0.0,58.84,2373,979.2,1009.8,39.8,,,,,
,59.25,651.7,989.4,1009.8,0.0,59.66,2310,979.2,1009.8,39.8,,,,,
,60.11,705.6,989.4,1009.8,0.0,60.55,2247,969.0,1009.8,39.8,,,,,
,60.98,828.1,989.4,999.6,0.0,61.43,2205,969.0,999.6,39.8,,,,,
,61.87,646.8,989.4,999.6,0.0,62.30,2142,969.0,999.6,39.8,,,,,
,62.71,558.6,989.4,999.6,0.0,63.10,2079,958.8,999.6,39.8,,,,,
,63.51,823.2,989.4,999.6,0.0,63.92,2037,958.8,999.6,39.8,,,,,
,64.37,637.0,989.4,999.6,0.0,64.79,1974,958.8,999.6,39.8,,,,,
,65.23,681.1,989.4,999.6,0.0,65.67,1911,958.8,989.4,39.4,,,,,
,66.11,725.2,989.4,989.4,0.0,66.55,1848,958.8,989.4,39.4,,,,,
,66.98,886.9,989.4,989.4,1.2,67.38,1806,979.2,989.4,39.0,,,,,
,67.78,803.6,989.4,989.4,9.0,68.19,1764,1020.0,989.4,38.6,,,,,
,68.62,906.5,989.4,989.4,18.0,69.05,1764,1254.6,989.4,24.3,,,,,
,69.49,641.9,989.4,989.4,30.2,69.93,1701,1264.8,999.6,24.7,,,,,
,70.37,769.3,989.4,999.6,31.0,70.81,1701,1285.2,999.6,22.7,,,,,
,71.24,720.3,989.4,999.6,31.0,71.65,1680,1275.0,999.6,22.3,,,,,
,72.06,798.7,989.4,999.6,30.6,72.48,1659,1275.0,999.6,21.5,,,,,
,72.90,749.7,989.4,999.6,31.0,73.34,1659,1275.0,999.6,19.9,,,,,
,73.79,818.3,989.4,999.6,27.5,74.23,1638,1213.8,999.6,20.7,,,,,
,74.67,862.4,989.4,989.4,28.6,75.10,1596,1264.8,999.6,19.9,,,,,
,75.54,916.3,989.4,999.6,30.2,75.96,1596,1275.0,999.6,19.9,,,,,
,76.38,700.7,989.4,999.6,29.8,76.80,1575,1275.0,999.6,19.9,,,,,
,77.22,725.2,989.4,999.6,29.8,77.64,1575,1275.0,999.6,19.9,,,,,
,78.08,837.9,989.4,999.6,29.8,78.52,1575,1275.0,999.6,19.9,,,,,
,78.96,637.0,989.4,999.6,29.8,79.40,1554,1285.2,999.6,20.3,,,,,
,79.84,705.6,989.4,999.6,30.2,80.28,1554,1285.2,999.6,19.9,,,,,
,80.69,641.9,989.4,999.6,29.8,81.10,1554,1285.2,999.6,19.9,,,,,
,81.53,744.8,989.4,999.6,29.0,81.96,1554,1285.2,999.6,19.9,,,,,
,82.38,627.2,989.4,999.6,27.8,82.82,1554,1264.8,999.6,20.3,,,,,
,83.26,681.1,989.4,999.6,28.2,83.70,1533,1264.8,999.6,19.9,,,,,
,84.14,700.7,989.4,999.6,28.2,84.58,1533,1254.6,999.6,20.3,,,,,
,84.98,690.9,989.4,999.6,27.5,85.37,1533,1264.8,999.6,19.9,,,,,
,85.78,676.2,989.4,999.6,27.5,86.20,1533,1264.8,999.6,19.9,,,,,
,86.64,671.3,989.4,999.6,27.5,87.06,1512,1254.6,999.6,19.9,,,,,
,87.50,656.6,989.4,999.6,26.7,87.94,1512,1254.6,999.6,19.9,,,,,
,88.38,651.7,989.4,999.6,27.1,88.82,1512,1264.8,999.6,19.9,,,,,
,89.25,627.2,989.4,999.6,26.7,89.63,1512,1244.4,999.6,19.9,,,,,
,90.03,597.8,989.4,999.6,26.3,90.47,1512,1244.4,999.6,19.9,,,,,
,90.90,617.4,989.4,999.6,25.9,91.32,1512,1244.4,989.4,19.9,,,,,
,91.76,602.7,989.4,989.4,25.5,92.20,1512,1234.2,989.4,19.9,,,,,
,92.64,637.0,989.4,989.4,23.5,93.08,1491,1213.8,989.4,19.9,,,,,
,93.51,666.4,989.4,989.4,23.9,93.91,1491,1224.0,989.4,19.9,,,,,
,94.31,676.2,989.4,989.4,24.3,94.73,1491,1234.2,989.4,19.9,,,,,
,95.15,656.6,989.4,989.4,25.1,95.58,1470,1254.6,989.4,19.9,,,,,
,96.02,656.6,989.4,989.4,26.3,96.46,1470,1254.6,999.6,19.9,,,,,
,96.90,646.8,989.4,999.6,26.7,97.34,1491,1264.8,999.6,19.9,,,,,
,97.78,597.8,989.4,999.6,26.7,98.18,1491,1275.0,999.6,19.9,,,,,
,98.59,622.3,989.4,999.6,27.1,99.00,1470,1275.0,999.6,19.9,,,,,
,99.43,632.1,989.4,999.6,28.2,99.86,1470,1326.0,999.6,19.9,,,,,
,100.30,632.1,989.4,999.6,33.3,100.74,1491,1479.0,1009.8,19.9,,,,,
,101.18,558.6,989.4,1020.0,32.5,101.62,1407,958.8,1009.8,36.3,,,,,
,102.06,558.6,989.4,1009.8,0.0,102.49,714,1448.4,1009.8,19.9,,,,,
,102.89,548.8,989.4,979.2,25.9,103.30,2016,1162.8,969.0,43.0,,,,,
,103.71,568.4,989.4,989.4,29.4,104.13,2058,1407.6,999.6,21.5,,,,,
,104.57,627.2,989.4,1020.0,40.0,105.02,2121,1713.6,1060.8,19.9,,,,,
,105.46,641.9,989.4,1101.6,48.6,105.90,2247,1785.0,1142.4,21.5,,,,,
,106.34,676.2,989.4,1162.8,48.2,106.78,2373,1887.0,1183.2,19.9,,,,,
,107.18,622.3,989.4,1193.4,53.7,107.59,2520,1907.4,1224.0,20.3,,,,,
,107.99,607.6,989.4,1234.2,53.3,108.41,2646,1897.2,1234.2,19.9,,,,,
,108.86,543.9,989.4,1213.8,53.3,109.29,2751,1887.0,1203.6,19.9,,,,,
,109.74,558.6,989.4,1224.0,53.3,110.18,2877,1897.2,1244.4,19.9,,,,,
,110.62,553.7,989.4,1264.8,53.3,111.06,2982,1887.0,1213.8,92.4,,,,,
,111.48,485.1,989.4,1173.0,53.3,111.87,3045,1876.8,1162.8,92.4,,,,,
,112.29,470.4,989.4,1152.6,53.3,112.73,3108,1866.6,1152.6,92.4,,,,,
,113.17,465.5,989.4,1152.6,52.2,113.61,3171,1652.4,1162.8,92.4,,,,,
,114.04,445.9,989.4,1162.8,29.4,114.47,3171,1234.2,1111.8,92.4,,,,,
,114.92,362.6,989.4,1060.8,26.3,115.36,3171,1387.2,1030.2,92.4,,,,,
,115.79,421.4,989.4,1060.8,32.2,116.19,3150,1326.0,1081.2,92.4,,,,,
,116.61,411.6,989.4,1071.0,29.8,117.05,3129,1285.2,1071.0,92.4,,,,,
,117.49,401.8,989.4,1071.0,29.4,117.93,3108,1315.8,1060.8,92.4,,,,,
