Passat CC tuled näitavad nina ette
tanelka
Auto: Seat Leon ST Cupra 300 4Drive
Lugemata postitus Postitas tanelka »
Probleem Passat CC esituledega. Peale auto käivitamist lööb veateate “No bend lightning (AFS) function” ja tuled näitavad kohe ninaette maha, samuti vilgub vedrustuse reguleerimisnupp. Panin kaabli külge ja jäid silma järgmised vead.
Kas viga võib põhjustada esimene parem kõrguse andur?
Address 14: Susp. Elect. Labels: None
Control Module Part Number: 3C0 907 376 HW: 3C0 907 376
Component and/or Version: DAEMPFUNGS-SG H07 0069
Software Coding: 030180
Work Shop Code: WSC 05314 000 00000
VCID: E6C3D0131192962E8EF-80B3
2 Faults Found:
03262 - Comfort Restriction
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 220159 km
Time Indication: 0
Date: 2032.14.29
Time: 18:31:58
Freeze Frame:
Error Code: 2
Bin. Bits: 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 220159 km
Time Indication: 0
Date: 2032.14.29
Time: 18:31:58
Freeze Frame:
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 C HW: 5M0 907 357 C
Component and/or Version: AFS-Steuergeraet 0136
Software Coding: 3493000
Work Shop Code: WSC 05311 000 00000
Additional Info: 1K0941329 AFS-Lst.-Modul l 0003 1K0941329 AFS-Lst.-Modul r 0003
VCID: 3467FA5B57CEB4BE40B-8061
1 Fault Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 103
Mileage: 220159 km
Time Indication: 0
Date: 2032.14.29
Time: 18:34:46
Freeze Frame:
Voltage: 13.63 V
Speed: 0.0 km/h
ABS 1
Skype: magnake
Tänanud: 42 korda
Tänatud: 197 korda
Re: Passat CC tuled näitavad nina ette
Selles viga ongi.
tanelka
Tänud!
Oskab keegi äkki sobiva anduri tootekoodi õelda?
tanelka
Andur vahetatud ja kõik toimib jälle nagu peab
