Lambda andur kas läbi?
harter
Lugemata postitus Postitas harter »
VW Polo 2008 1,2 käisin VAG kaabliga kontrollimas ja tuli 2 vea teadet . Mida vahetama pean ?
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ8Y120333 Mileage: 83840km/52095miles
Address 01: Engine Labels: Redir Fail!
Part No: 03D 906 023
Component: SIMOS91 1.2l 2V 5413
Revision: --H04--- Serial number: VWZ5Z0GN221802
Coding: 0000031
Shop #: WSC 00788 785 00200
VCID: DBB5F1E719D0DBC6211-5000
2 Faults Found:
16524 - Oxygen (Lambda) Sensor B1 S2
P0140 - 009 - No Activity - Intermittent
Freeze Frame:
RPM: 896 /min
Bin. Bits: 00000100
Voltage: 0.460 V
Voltage: 0.820 V
RPM: 832 /min
Bin. Bits: 00000100
Voltage: 0.420 V
Voltage: 0.140 V
16520 - Oxygen (Lambda) Sensor B1 S2
P0136 - 008 - Malfunction in Circuit - Intermittent
Freeze Frame:
Temperature: 600.0°C
Resistance: 65.52 kOhm
Voltage: 0.460 V
Bin. Bits: 00000100
Temperature: 840.0°C
Voltage: 0.420 V
Bin. Bits: 00000100
Readiness: N/A
Reaalselt tuleks lambda tööd diagnostikaseadmega kontrollida, kuidas pinge käitub. Hakatuseks kustuta need koodid ära ja vaata kas tulevad tagasi.
harter
Jah tulid tagasi
tlauri
Tänatud: 17 korda
10 aastat vana. Vaheta ära.
