2015 3.0tdi Touareg probleem mootoriga
Harti
Telefon: 56143140
Auto: Passat B5 4Motion, Touareg 7P, L322
Tänanud: 10 korda
Lugemata postitus Postitas Harti »
kas keegi suudaks mulle selgeks teha, mis võiks täpsemalt viga olla?
VCDS annab sellise vea:
Address 01: Engine Labels:
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55E903CDB4C1576279D8A-FFFE
1 Fault Found:
It means go to engine 01 then 10 Adaption then channel 091 and report the value.
5080 - Injector: Cylinder 2 (N31)
P0202 00 [00100100] - Circuit Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 201359 km
Date: 2025.10.18
Time: 16:38:47
Engine speed: 2787.50 /min
Normed load value: 97.6 %
Vehicle speed: 42 km/h
Coolant temperature: 25 °C
Intake air temperature: 7 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.520 V
Unlearning counter according OBD: 40
Allowed number of injections-Bits 0-7: 3
Injection release status-Bits 0-7: 56
Desired injection characteristic-Bits 0-7: 56
Mean injection quantity: 73.09 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1724400 hPa
Control Module temperature: 13.9 °C
Readiness: N/A
gaas põhja vajutada, viskab limp mode peale, vilgutab eelsüüte tuld ja käib nagu ainult 3 pütaga. keerad auto seisu ning siis käima, saab rahulikult sõita.
Nelivedu, kindel edu!
2.pihusti viga (kaabeldus?) mis läheb ja tuleb?
